Old 07-24-2011, 07:16 PM   #8 (permalink)
doc1969
drv2die,
Thank you. I did find the towing info you mentioned. As for the shifting from 5th to 2nd, I also realized that, too, when I first got the car in April. It wouldn't shift and I figured it must be computer controlled. Overall, I still shift to Neutral when possible as said before. I just wanted to make sure that I was not going to screw up the transmission prematurely.
