Old 07-24-2011, 06:58 PM   #38 (permalink)
graydonengineering
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by mwebb View Post
just use bolts
drill and tap
do not drill through the plastic , punch through using the holes drilled through the wheel as a guide , then use a tapered punch , twisting by hand to expand the holes enough to fit the bolts .
4 bolts is fine up to 70 mph , i never go faster so i dunno if 4 bolts is good enough at 71 mph or above
That looks good! What did you use for the plastic cover?
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
