07-24-2011, 09:29 PM
#12 (permalink)
Originally Posted by White118
That's some help, thank you for the info I'll check around and see if I can get some taller rims and tires, hoping to get rims for free.
-Matt
i do not believe you will be able to get them for "free"
but
half of the fun of buying on craigslist is the negotiations prior to consummating the transaction
195 60 15 tires will fit as well
185 65 15 and 195 60 15 will fit on the rear , but not on the front
in this case
LRR is king do research on the LRR tires in that size and buy them used on craiglist as well
a tire worn 50% rolls better than the same tire , brand new , assuming the tire is worn evenly and the belts are UN damaged .
