Would it fit on the splines of the steering column? Who knows. Would you be able to wire up the controls? If you are asking here then I would say you should probably avoid it. None of that wiring will exist in your current column. Don't even think about trying to mod in the airbag / impact sensors/ etc if you don't know what you are doing.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
