Old 07-27-2011, 05:57 AM   #2 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Atmega328 is the chip on board, there are 13 digital IO and 6 Analog.
It's definitely able to run the OBDuino & MPGuino code without doubt, the board has 'pins' on it (instead of the header 'holes') that the older boards had - to get around that, the jumper wires will need to be female->male (depending on the LCD you are interfacing with, and how your hardware will go together).
It's nice to see a smaller board though!
The Following User Says Thank You to toc For This Useful Post:
madsoul (07-27-2011)
