Originally Posted by Ryland
Over sized exhaust will cause problems that could build up over time like slowly fowling your o2 sensor, also check your spark plugs (every 15,000 miles) and change them as needed with stock copper core V-power plugs.
What fluid did they put in your rebuilt transmission? it should either be motor oil (5w 30 I think is stock, 0W 30 works well) or Honda MTF, gear oil has sulpher in it that will destroy the bearings and bushings.
The spark plugs were changed 30,000 miles ago. I will check them.
I bought a case of Honda MTF and had them use that on the refill.
