Old 07-28-2011, 02:42 PM   #20 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Vekke, do you have the VW Self-Study Programme 218 on The Lupo 3L (pdf, 3.2 MB)
If you want it, I can email it to you.
"The engine is shut down automatically when the vehicle is stationary and first gear is selected. The can be started as soon as the driver's door is closed and the brake pedal is pressed."
"What conditions must be met before the engine is shut down automatically?
1. 6a.
The gate selector lever is in position E.
2. 6b.
Economy mode is active.
3. 6c.
The brake must be kept pressed down for at least three seconds.
4. 6d.
The brake pressure switch indicates that a certain brake pressure is being applied to the brakes.
5. 6e.
The ABS wheel speed sensor, as well as the gearbox speed sender and the speedometer sender signal to the system that the vehicle is stationary.
The coolant temperature must be higher than 17 ° C.
The intake air temperature must be higher than 0 ° C.
The auxiliary heater must not be switched on.
The headlights must be switched off.
The alternator load factor must not exceed 55%."
Having the radio on can cause the 3L not to shut down !
"How does the vehicle resume operation?
1. 4.
The driver releases the brake pedal.
2. 5.
The gearbox control unit starts the engine.
The gearbox control unit ends the starting cycle and allows the starter to disengage."
Try to find Self-Study Programmes No. 209 and No. 221.
The Following 3 Users Say Thank You to euromodder For This Useful Post:
bikeprof (03-07-2013), Piwoslaw (07-28-2011), Vekke (07-28-2011)
