Old 07-28-2011, 05:06 PM   #16 (permalink)
aerohead
bellypan/airdam
Originally Posted by pnambic View Post
Someone correct me if I'm wrong, but I believe the school of thought is as follows:
- the underside of a vehicle without a tray is a big source of drag.
- a simpler step than building a full undertray is to build an airdam and side skirts, essentially limiting the air going under the vehicle in the hopes of minimizing the drag. But creating a front airdam increases your frontal area increasing air resistance. It can also create downforce, which hurts fuel efficiency as well. Its a tradeoff and better than nothing.
- Building a full undertray is the better, though more difficult option as it minimizes underbody drag while making the smallest increase to frontal area possible.
If you already have a full undertray, adding a significant airdam and side skirts would probably be more detrimental than helpful.
hth
*The underside of a car can contribute 12% of overall drag.
*A 1960s Citroen DS19 won't benefit from a pan like a Jeep,as the Citroen already has a full pan.The benefit will be on a case specific basis.
*Short of 'doing' a bellypan,the airdam can serve as a palliative,helping to prevent air from getting into the torture-chamber under the car.
*The airdam typically cuts lift,rather than create downforce,although they can certainly be configured for downforce.
*The airdam can be constructed such that it not increase frontal area.
*Even if the airdam increases frontal area,it can still cut drag up to a point,then there is going to be a point where the gain begins to fall off.You'd have to test for that.
* Oddly enough,some of the lowest drag concept cars with full bellypans,also have active airdams which lower at speed to block air from the 'ideal' underside.
* With respect to side skirts,I don't have any data on that.
