Originally Posted by Cd
why would VW and Audi go through all the trouble of creating the dimples if they did not have a function ?
If they are for rigidity, why choose a dimpled shape versus the more common ridges
I have a few educated guesses.
It helps rigidity, it's probably easier and lighter to make out of a flat sheet - sharp angles also concentrate stress when thermoforming plastics.
A circle keeps the same aspect from every angle.
Flow underneath the car isn't lengthwise, and the angle will vary with speed.
Ridges will interfere with the actual flow pattern.
Also of note is how well that VW has tucked the underside into the bumper - nice and flush.
