...the one, single-most, important thing you can do is to be "...100% aware..." of your gas milage: as you drive and sit idling!
...and, you can do that by using one of the many MPG meter devices available, such as the ScanGauge II™ (SGII) and the UltraGauge™ (UG)...for you, I'd recommend the UG as it's both less complex and less costly.
...with it there on your dash, constantly "showing" you what your MPG is as you drive, you'll soon become "100% aware" of what HELPs you get better MPG and what HINDERS your MPG.
