Glide, Load, Engine On, Neutral?
Pulse & Glide = Get the car up to speed, and glide to a lower speed, and then accelerate again.
I would Glide with the car in the highest gear, unless I was looking to build momentum, in which case, I would glide in Neutral.
Pulse - I would pulse up to the speed limit.
Can someone explain for me what Glide, Load, Engine On, Neutral is exactly?
How does this work up hill - if you glide uphill, you'll lose momentum and have to get it back - and in many hills that momentum is gone as soon as you get it?
Ahh: Found this:
http://ecomodder.com/forum/showthrea...tml#post248966
Still, how does that work on hills exactly?
