Old 07-30-2011, 01:59 PM   #5 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by toc View Post
I can either pulse and glide between 55 & 70kph, or get it to 70 in 5th gear
With a petrol car, P&G should be more efficient.
and not go hard on the pedal (maintain steady throttle position).
Accelerate at the BSFC - it'll be at a fairly high load
An Idling car wastes fuel.
True, and that's where the major gain is with P&G : the engine gets shutdown on the glide.
In fact, you are better off in gear going down hills, as your car will cut fuel, as it also will in gear and no throttle.
But you'd be (engine) braking.
That means this technique is less efficient, unless you actually need the braking action to keep your speed within legal or comfort limits.
If in neutral, it will still use fuel, but with the engine unloaded (in neutral), the car will glide further - using fuel to idle as it glides.
My car consumes about 0.5 L/H.
Doing 100 kph, I'm seeing 0.5 L/100km or 470 mpg.
If I do 50 kph, I'm getting 1L/100km or 235mpg.
It'd be stupid to pass that up !
Under 15kph, I'm getting too close to my target fuel economy (4 L/100km - 58.8 mpg) for it to be worthwhile.
Which is better, why?
Coasting with the engine on is ultimately more efficient than rolling in (any) gear, and having the engine slow you down.
It's just a matter of properly matching your initial speed to the length of the glide.
I was an avid user of engine braking, getting good - not great - mileage out of any car I've driven.
Coasting engine-on improved my mileage considerably.
