Originally Posted by t vago
You could make an aerocap out of that foam. I wouldn't place it on the underside of your truck, because of its flammability and nearness to the exhaust.
Will be redoing the exhaust at the same time on a lift. Really, if people think that Coroplast is non flammable and THAT's ok under there, then you're sadly mistaken. Now, if you do your research, it's probably MUCH less flammable than most other things, but the foam I'm refering to is actually a part flame retardant for building structures between block and bricks that we use on our construction sites. This is NOT your normal foam, it's slightly different, and it's actually 1 1/2" so it may not be ideal anyways.
I will probably wait until I get to a job where they are tearing out some ductwork or something to get the sheetmetal and use that perhaps.
I don't really have a cheap coroplast supply around here.
