Old 07-31-2011, 06:27 PM   #1 (permalink)
White118
White118's Avatar
Bandit - '97 Geo Metro
rear wheel skirts
Built my brackets today I used some 1/8" box steel drilled some wholes in it and tapped the wholes. Making L brackets just going to screw the brackets to the wheel well lip and then use some wide rim bolts and some coroplast sheeting and some aluminum strips on the bottom to make them stronger on the the bottom. I'll post some pictures when I get them on and pic up the sheeting.
-Matt
The Following User Says Thank You to White118 For This Useful Post:
aerohead (08-02-2011)
