Old 08-01-2011, 06:04 PM   #4965 (permalink)
jackbauer
jackbauer's Avatar
If you have a laptop you could run rtd explorer or build the cougar lcd display system. The chill plate is the most expensive part. I had mine custom made. That said I see a guy now selling chill plates for the Curtis 1238 AC controller for $100. Can't be much work to adapt that.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
