The CV shafts do not care if you are lugging the engine or not because they are seeing the torque that it takes to move the car.
But if you are driving in such a way as your car is bucking then you are way to high of a gear and are going to wear out things like engine mounts first, you could wear out your clutch springs as well and that is going to be a costly repair.
