Old 08-02-2011, 02:48 PM   #97 (permalink)
Charles7a
Hi Lee,
Are the MPGuino settings on your webpage the current settings you are using for your motor-home? I have a similar motor-home and have just received my MPGuino in the mail.
My motor-home is a 28' Class A 1995 Winnebago Warrior w/ a TBI 454. I have been using a netbook, TunerPro, and an ADL cable to get instant MPG for my motor-home. The MPGuino will be a simpler setup.
Modifications so far:
AquaTune AquaThrust Plus HB
AirTabs
Synthetic engine oil
Fabricated cold air intake
Fabricated front air dam
Accel Super Coil
8.5 MM Spark Plug Wires
K&N air filter
All 6 tires inflated to 90PSI
I am curious to find out if your fabricated wheel well covers/skirts made a difference. In my previous motor-home I used AirTabs in front of the wheel wells to redirect the airflow around the wheel wells. I also had AirTabs in front of the large truck style mirrors and at the rear of the roof-top A/C. I was aiming for "the ugliest motor-home on the road" since that motor-home was ugly to begin with. My current motor-home only has AirTabs at the rear of the motor-home. For now...
My fabricated air dam wraps around to the front wheel wells and goes down to ~5" above ground. It is flexible enough to withstand "eating curbs".
Charles
