Old 08-05-2011, 08:41 AM   #381 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by DJBecker View Post
I hope you understand that the real point of this was so that I could write a CAN bus extension for you. To do that I needed to get a better understanding of your code so that I could make minimal changes. If you look at the CAN add-on I did for the Cougar code, I managed to hook into it with only two lines added to the main source file.
I hope that you share the CAN bus "hardware" changes you made for the Cougar LCD & Controller too.
It would be nice to have a simple CAN bus interface for the LCD & Controller.
