Old 08-05-2011, 05:56 PM   #7 (permalink)
Frank Lee
We don't have enough info. For example, how much range are you seeking? That leads to what battery tech you plan to use and if it's lead acid and longer range then you need a base vehicle with a higher load capacity, like a small pickup, but then if you need four seats you'd want something else and....
newguyintown (08-05-2011)
