Originally Posted by hackish
This is true, although many newer vehicles are staying in closed loop much longer. Some of them will stay closed loop for everything but WOT.
I just did some testing on a 1.9l TDI and actually found that the engine was more efficient under higher load with more fuel than factory. Surprised me but I don't tend to tune a lot of Diesels. Sadly, adding fuel sure didn't help the emissions. The HC and particulate readings were sky high
That's odd. I've tuned diesels and it's pretty odd for efficiency and PM/HC to both increase (ususally you'll see efficiency & NOx go together). It does happen on occasion, however, if the conditions are just right. Since it's a turbo remember that adding more fuel will alter where you are on the turbo maps. That will change your efficiency as well (maybe good or bad).
