I agree that 4500 rpm is too high. I haven't seen that in over a year.
The advantage of pulsing uphill is that it's easier to put the engine into a high-load operating range. You have to accelerate very quickly to get that load downhill, or you use a lower-load, less efficient range. Also, like mentioned above, aero drag and reasonable speeds become an issue with pulsing downhill.
![](http://ecomodder.com/forum/fe-graphs/sig268a.png)
