Old 08-07-2011, 03:45 PM   #2 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
don't dip, paint over with a brush. The fiberglass will make a huge mess if you try to dip it.
That said, I don't know how good that will work with slick metal. Typical epoxy prep is done with rough sandpaper to give the epoxy resin some "tooth" to grab onto.
So, if you used galvanized metal now you are making potential rust areas, unless you intend to 'glass over the whole thing.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
