Old 08-07-2011, 06:22 PM   #1 (permalink)
orbywan
Aero RV Belly Pan(s)
A month or so ago I built a boat tail for my 95 Ford E-350 Class C RV. It was a lot of work but it was also a lot of fun. The first and only test run so far, showed a 32% improvement on the easy half of the trip, and an average of 23% improvement for the round trip so I‘m really happy with the results so far. The airflow on the sides and the top are pretty good, but the airflow on the bottom was not.
So, the logical thing to do is finish the overall concept and skin the undercarriage to see it’s full potential and try to improve the flow on the bottom side of the tail, which will probably end up being reconfigured.
I broke the pans down in segments. The first 6 photos are of pan # 1, which goes from the front I-beams forward to the front bumper.
Pan # 2 runs from the I-beams back to the transmission crossmember, those are photos 7 – 11. So I don’t write a book with the first post, I’ll post the photos for Pan # 3 in the next post.
I had a really big piece of cardboard laying around so I used that to make templates for pans 1 and 2, then tested the suspension, made some adjustments and made the coroplast pans from the template.
When time permits I’ll also fabricate some wheel pants or spats for the front and especially the duallies in the rear. There has to be some serious turbulence around there. They will have to be easily removable since we take this vehicle off road occasionally.
Name:	Pan 1, photo 1.jpg
ID:	9174   Click image for larger version
Name:	Pan 1, photo 2 wb .jpg
ID:	9175   Click image for larger version
Name:	Pan 1, photo 3 wb .jpg
ID:	9176   Click image for larger version
Name:	Pan 1, photo 3.5 wb .jpg
ID:	9177   Click image for larger version
Name:	Pan 1, photo 4 wb .jpg
Name:	Pan 1, photo 5 wb .jpg
ID:	9179   Click image for larger version
Name:	Pan 2, photo 1 wb .jpg
ID:	9180   Click image for larger version
Name:	Pan 2, photo 2 wb .jpg
ID:	9181   Click image for larger version
Name:	Pan 2, photo 3 wb .jpg
ID:	9182   Click image for larger version
Name:	Pan 2, photo 4 wb .jpg
Name:	Pan 2, photo 5 wb .jpg
The Following 9 Users Say Thank You to orbywan For This Useful Post:
aerohead (08-13-2011), ausias (09-14-2011), beatr911 (01-12-2012), graydonengineering (09-04-2011), JasonG (08-21-2011), KamperBob (08-08-2011), landsailor (08-08-2011), TRaction (09-14-2011), turbothrush (03-16-2012)
