Old 08-07-2011, 10:31 PM   #53 (permalink)
jime57
OurInsight - '06 Honda Insight
The 1st-gen Insight has separation.
Are you sure of this Phil. I have not seen wind tunnel smoke or tell tail data which would indicate separation. From the work that 3 Wheeler did, I though the rear met the template, if indeed that is an indicator. The rear most portion is only about 18 deg by my measurement. Could it have a Cd=.25 if it had separation?
