Old 08-08-2011, 11:07 AM   #5 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
I meant to update!
Pin 12 & 13 are described as TX / RX for Nissan Consult I protocol, which was previously used as OBD connections, but now doesn't talk to the ECU, just perhaps, ABS, SRS.
ECU is on Pin 7 apparently, and would either be Consult II & OBD II, or just Consult II.
I'm keen on chasing out the ECU pins, I'm hopeful I'll find a CAN across there somewhere, whether that'll help make an OBDuino or not is another story.
Consult II doesn't have as much info as Consult I in terms of protocol. OBDII didn't seem to work with the ELM327 cable. CAN is mentioned as being in the 2003 model Sentra's, and my VIN coincides with what I think is the Sentra VIN. Sentra being the US market - Pulsar being Australian. I thought Nissan Sunny would be it.
I'm really avoiding the urge to just go at the injectors and setup an MPGuino instead. I *hope* I can find CAN lines at the ECU - if that helps make an OBDuino I'll be unsure.
