Originally Posted by MGB=MPG
there are those [D. Vizard}who would say the constant depression SU Carb can out perform sophisticated computer monitored systems , after all the computer monitored sys are only as good as the programming and the SU works analog on density altitude as detected by the Flow .
The old SU was a very fine device for FE and precise fuel metering although I don't know if Mr Vizard would still advocate an SU over FI for every application these days, although for an older engine like the B it would probably be preferred.
I think he (or someone using his name) posts
here.
Have you de-smogged your B ?
