Hi guys
First test - powered it up - no smoke!
the green and yellow LED's both lit up - continuous - I hope that's correct!
I assume (hope) the microprocessor that came with the kit has the basic software so I can now finish assembling my car and hook up the controller
- I will test it with a 12v battery before using the main system
I assume that it will now try and give me motor current
Throttle pot
Zero ohms = zero amps
5,000 ohms = 500 amps
