Chargers are in. I plan to build a modular box for the batteries/chargers and hook it all up to an anderson power pole connector so that I can remove the batteries if need be for cargo.
That said, I got the belt on and gave it a test run. The motor is spinning the wrong way! Whenever I applied throttle it tried to stall the engine. Oh well, it's just a matter of switching a wire or 2 around to get it to spin the right way.
