Old 08-09-2011, 10:08 PM   #152 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Learning from the earlier versions...
So I'm thinking...how to setup the rear window. I'm thinking a piano hinge attached to some more Lexan that's below the metal stud. Incorporate a center latching/locking setup like what you would find on a camper top. This would allow me to unlatch, flip the rear window up enough to open/drop the tailgate down without lifting the entire cap up. This would allow me to use the hatch to keep others from opening the tailgate...since ours don't have a factory locking setup.
The previous versions had a static window which required me to have the hatch as high as possible to clear the bottom of the window. With the hinged window, I should be able to clear it without worrying about smacking the bottom of the window with something.
If I go with the domed version...my rear view is much better. If I go flat, I'll be left with the hinged window. More brainstorming to do...
Dark Aero-The world's first aerodynamic single wheel boat tail!
