Originally Posted by roosterk0031
I have 03 Malibu, 95 degrees out today, ac on/recirc on for first 15 miles temp OK. Turn ac off, recirc on, no change in temperature inside car for 15 minutes, turn recirc off, humidity & temp rises in minutes. I think the recirute button overrides the ac switch, it was without adoubt running, no change switching ac button on or off, all highway so I couldn't feel it cycling but I know it was. I'll try with the 10 Impala I bet it works the same.
Yeah, that makes sense, otherwise you would end up with too much humidity in the car over time, which is definitely a bad thing.
Originally Posted by Neddy Seagoon
When driving my car I just use the Defrost setting it cools the car just nicely for me with out freezing me
Not very humid where you live? I think in some areas if you did this you'd get condensation on the outside of your windshield.
