Thread: Which O2 sensor
Old 08-10-2011, 04:21 PM   #3 (permalink)
Ford Man
Check the codes and get them defined. If the definition is sensor 1 Bank 1 it's the upstream sensor for cylinders 1-3, if the definition is sensor 1 bank 2 it's the upstream sensor for cylinder 4-6, if it's sensor 2 bank 1 it's the downstream sensor for cylinders 1-3, and if it sensor 2 bank 2 it's the downstream sensor for cylinders 4-6. The upstream sensor is the pre catalytic converter sensor and the downstream sensor is the post catalytic converter sensor.
The Following User Says Thank You to Ford Man For This Useful Post:
Kodak (08-10-2011)
