Thread: Actron 9185
Old 08-10-2011, 08:27 PM   #8 (permalink)
p38fln
Escape #2 - '13 Ford Escape Titanium
C-max - '17 Ford C-Max SE
My 1999 Rav4 (Which did have OBD-II) didn't have a MAF sensor and so couldn't give instant fuel economy, even though it was compatible with OBD-II. It had a MAP sensor instead, which is pretty much useless for fuel flow.
Does your Prizm even have a MAF sensor?
*edit - I see that there's an open source OBD-II scanner available that can imitate a MAF from the MAP sensor after calibration and entering the engine size. Since my vehicles after the Rav4 have all had MAF sensors I haven't had to check it out. Still won't help you on your Toyota --
The Toyota scan tool for an OBD-I Toyota is almost $8,000, not sure if theres an aftermarket version available.
