Old 08-10-2011, 09:53 PM   #257 (permalink)
deathtrain
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
Originally Posted by brucey View Post
Yup, I've been burning the midnight oil trying to get this operational. It's been a LOT of work, right now the big problem is the motor is spinning the wrong way (CC When it should be spinning clockwise) and the wiring diagram says simply hook up the yellow wire instead, but my harness has no yellow wire or anything in pin 33... I'm waiting to hear back from the MFG or someone over in the EV forum.
Diagram, for anyone that wants to give an idea http://www.electricautosports.com/fi...-2009%29_0.pdf
Looking at that I would try the following
AC motor's are usually ABC or CBA try switching the A and C around. that should reveres the direction. After that I would need to know how close your design is to the actual diagram you used.
