Old 08-11-2011, 11:23 AM   #258 (permalink)
Boreas
Boreas's Avatar
Hello Brucey, I'd like to thank you for taking the time to document your project. I've been following it from the start. I'm a two finger typist so I haven't taken the time to reply before. It looks like on your diagram, If you took the red wire on pin 25 (12v+) and connected it to pin 33 after disconnecting the white wire, pin 22, the controller will reverse the motor. See note 2 just backward. That's all the forward-reverse switch is doing. My guess why you don't have a yellow wire is that your wiring harness is not set up for reverse. Keep up the good work. Boreas
