Old 08-11-2011, 02:26 PM   #12 (permalink)
oil pan 4
Originally Posted by Phantom View Post
One thing I will recommend is to keep the exhaust temp up after the turbo so it does not slow causing back pressure.
I am going to use a 3.5'' to 4 inch straight pipe that dumps forward of the rear tire. Back pressure will be nearly 0.
I have looked at pictures of different setups using the banks turbo manifold and it looks like a good idea to at least wrap some stuff on the passanger side.
Originally Posted by Tygen1 View Post
IE, pull your fuel back to get it as lean as possible.
I am running a diesel engine so it always runs as lean as possible at light and medium load. Stuffing more air mass into the cylinder will help it run even leaner.
