Old 08-11-2011, 07:24 PM   #81 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Used some epoxy resin to glue it to the actual upper grille assembly. The bond to the grille is good enough to withstand the elements. I only used a tiny amount of resin, so removing the grille block will not be that hard if I ever decide to, which I doubt ! That one is permanent.
