Old 08-13-2011, 12:49 PM   #9 (permalink)
Arragonis
The PRC.
Originally Posted by actwithclarity View Post
Just did 450km of of P&G around the city in my 91 metro, and I only gained 1 MPG over normal driving.
I was pulsing with normal (~3/4) throttle, in normal shift range, timing my pulses for as little braking as possible, no EOC. Basically it was all going smooth (other than my slightly jerky revmatching skills), lots of my glides were 3-4x longer than pulses, and I was hoping for better results.
My car seems well mechanically other than (I believe) a dirty/corroded fuel tank, where sometimes the fuel supply (accelerator) is weak.
What can be wrong?
What were the actual MPG figures both before and after, could you actually get exactly the same MPG on the same route or tank to tank ? I ask because a 1 MPG difference seems within any margin of error to me. I'm probably not the most precise around here but I think any tank to tank with a difference of under 3 is probably no change at all.
I'm interested in the techniques you may use though, I have switched from a TDi to a small petrol car and the pulses take a lot longer than they did. I used to be able to go from 60-80 in about 3-4 seconds. Now I don't go much above 65 and it takes a good 5-10 second pulse to get there.
Also do you have any other mods, e.g. tyre pressures higher or aero mods / deletes.
