Originally Posted by aerohead
The university solar cars are a candy store for wheel fairing images.Ditto for their ultra-high mpg burn-and-coast wundercars.UC Davis.Univ of Michigan,etc..Honda Dream 2 Solar car,NUNA-3 ( Cd 0.077 ).
Thanks Phil, I’ll check those out. I saw your photos on the progress on the boat tail trailer, looks like you're making progress.
When are you leaving on your trip?
OK, pan # 5 is completed and installed. I used some fiberglass insulation on the cat and right behind the down pipe (photo # 10) since it is so close to the trans and now enclosed. I also put a vent right under the cat to help get some heat out. I also fabbed new driveshaft safety loops since the old ones hung down to the ground. Other than that it was just a big pain in neck panel.
Next up is the differential. My brain is cooked from the heat, hopefully inspiration for that will visit me in my sleep tonight. Ha.
