Originally Posted by newguyintown
Regarding the side load, I was thinking it might be possible to mount one motor on each side of the axle. Would that help reduce stress on the motor? Or could I possibly run it through the bike chain?
If you can get one of the kits, it should be possible to swap the bearings for a type that can handle the side load better. BTW, with the outrunners, it should be possible to modify the bell ( the outer, rotating part ) to be better adapted to the wheel, including the position and types of bearings.
Regards
Dawid
