Old 08-15-2011, 01:51 AM   #27 (permalink)
George Tyler
chemically correct mixture will burn at the highest temperature, right? So EGT will be lower when you run lean at first, then increase when the mixture is burning so slowly that it is still burning in the exhaust, this is when you start burning valves etc. That makes the optimum EGT the lowest temperature you get?
