Fellas,
This is really intersting stuff! I have a small wind turbine at my house that is based on a PMA(Permanent Magnet Alternator). It is more efficient than it's rotor excited counterparts such as car alternators that use up to 30-50 watts to get going. The only issue I have had with mine is that the voltage varies with rotor RPM which is to be expected of course. I am using very low voltage drop Schottkey diodes to rectify the 3 phase output to DC. Since the DC voltage varied so much, I needed a way to tame it and make it usefull. I ended up finding some DC-DC converters on Ebay that have the unique ability to take anywhere from 18-75 Vdc and put out a constant user adjustable voltage output. Overall the system works quite well. I wonder if rectifying the car alternator output with some low voltage drop diodes(like mentioned above) and coupled with using DC-DC converters could increase the alternators efficiency a bit?
 2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
