Old 08-15-2011, 07:30 PM   #9 (permalink)
RandomFact314
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 28.73 mpg (US)
OK so I went out and bought another 4 fuses the other day so I can try to figure this problem out.
Try 1: Went outside and pulled out the brake bulbs and put a new fuse in, it blew instantly.
Try 2: I started looking around for noticeably odd wiring, and thought "Well if I can just get my 3ed brake light to work then It will atleast be more safe" so I looked at it and noticed it was unplugged and the wires that plugged into it was plugged into something else so I unplugged that and put a new fuse in.
Turned on the lights and the tails DO light up now! woot!
Now I just gotta go buy some bulbs because out of the 2 in the car and the extra 2 I had in the house, only 1 worked. I had another one that just did the low beam but not the high (for when you touch the breaks)
BTW: Horn works now too! yay
