Old 08-15-2011, 10:40 PM   #30 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by Arragonis View Post
That accepted I read somewhere that bulbs last longer with use. Car bulbs that is, not house ones.
Kind of interesting that if you look at a DC powered light bulb you will notice over time that the inside of the bulb gets a silvery coating. Know what that is? It's bulb material that has been sputtered from the filament and coated the glass. There is low pressure inside the bulb that allows the filament to reach a high temperture(hence white light) without burning out. Low pressure and heat can cause material migration.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
