Old 08-16-2011, 02:40 PM   #13 (permalink)
Daox
I should also add that you can change the duration each bar represents. By default, the bars change quite quickly. You see a new bar about every 9 seconds. There are 10 bars total, so you see about 1.5 minutes of history. This is great for short sections of your commute where you want to try to improve upon it. However, you can also extend the time period between bars so that you don't get so many peaks and valleys and it shows a more averaged out reading.
