Old 08-16-2011, 05:19 PM   #180 (permalink)
aerohead
underside
Originally Posted by Vekke View Post
https://www.facebook.com/media/set/?...type=1&theater
Can I do the underside same way. Make correct size and Flip the template over and put it on the same place as roof side template. Or do I have to use the lower half of the template to underside of the boattail also?
Vekke,the underside is covered in Hucho's section on diffusers.
The upsweep angle of the diffuser will depend on where the upsweep originates.
I believe that if before the rear axle,the angle can be as steep as 4-degrees.
If it starts after the rear axle,then 2.5-degrees is the limit.Please check Hucho's work to verify.
