Old 08-16-2011, 10:25 PM   #42 (permalink)
orbywan
Pan #7
Pan 7 is in, will need some trimming but it’s done for now. Decided to take the easy way out and just bring it up to the differential for now. The articulated cover will have to wait. My patience is wearing thin and things are really busy work-wise. The last photo is what’s up next.
After that I just have to make a transition so the air coming off the differential flows into pan #9 at the rear as well as possible. I'm seeing a glow at the end of the tunnel. Can't wait to test this out and see if all this work was worth it.
Name:	Pan 7, photo 1.jpg
ID:	9272   Click image for larger version
Name:	Pan 7, photo 2 wb .jpg
ID:	9273   Click image for larger version
Name:	Pan 7, photo 3 wb .jpg
ID:	9274   Click image for larger version
Name:	Pan 7, photo 4 wb .jpg
ID:	9275   Click image for larger version
Name:	Pan 7, photo 5 wb .jpg
Name:	Pan 7, photo 6 wb .jpg
ID:	9277   Click image for larger version
Name:	Pan 7, photo 7 wb .jpg
ID:	9278   Click image for larger version
Name:	Pan 7, photo 8 wb .jpg
ID:	9279   Click image for larger version
Name:	Pan 7, photo 9.jpg
The Following User Says Thank You to orbywan For This Useful Post:
BamZipPow (08-17-2011)
