Old 08-17-2011, 03:26 AM   #10 (permalink)
Peter7307
Can't help thinking the wheelarch "ears" are NOT helping !
Sorry to be cynical here but .28 is not all that good.
Citroen managed .29 in 1974...also on a 4 door , 5 seater production sedan ;the CX model.
The original version had .30 but later variants had .28 / .29 depending on equipment and specs etc.
Panel fit was somewhat umm... variable (yes we'll call it that to be kind) and there were gaps you could put your fingers through (between the headlight and the bumper for example) so some "tweaking" should be able to drop the numbers even further.
Peter.
