Old 08-17-2011, 05:09 AM   #25 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Patrick View Post
I think there may be some gains available on the front.
The rounded-front bullet shape has about 1/4 the drag of a flat plate.
The flat plate is obviously the worst-case scenario.
Beyond a bullet-shaped front, what most car mirrors approximate anyway, the gains are made at the back.
A carefully designed mirror-car body blending (Opel Vectra / Vauxhall Cavalier ? can help reduce drag and noise, while being ahead of the mirror plane.
If you look at mirror housings, some are tapered at the rear - at least on the C30/S40/V50 range Volvo used this trick.
