LPG systems in that price range usually self tune via the stock ECU. But that's programmed to maintain an air-fuel ratio that's beneficial for gasoline, not LPG. Still... if you don't want to overcomplicate, I won't go into O2-sensor intercepts...
You still might see a little power gain via timing adjustment, though.
