Just learned about the "Smart Alternator" Kia and other companies use. As you probably know it's quite simple in principle, and would be easy to implement with a couple sensors and a simple PLC setup.
![](https://ecomodder.com/forum/avatars/josh8loop.gif?type=sigpic&dateline=1335377968) 2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
